What is this CMS-GE part?
hcoyote
I'm trying to identify what this part does on the CMS-GE. I can't find it in the manuals that came with it, nor do I see it in the supplemental one. It clearly fits on the V-groove, but I'm not sure if its function. Can someone point me in the right direction?
Thanks!
Figures! Two minutes after I post this, I run across it on the part list for the dust hoses. Looks like a clamp to hold the smaller hose so it can connect to a collection point on top of the CMS when used with a different tool configuration.
Yes, for example when using the TS plate the small hose will connect to the blade guard and without that holder the hose tends to fall off or be in the way on the outfeed side.
Meh..  Which unit did that come with as I can see the use but didn't get one with my CMS, the Router plate or the TS55 plate :(
Ahhh, I didn't get the hose kit I built my own from bits and a 36mm hose I needed.
It should come with all CMS sets. I had it with my VL and use it more to keep the hose out of the way with my TS 75 plate. Comes in very handy when connected to to the blade guard to extract the little dust that comes out topside.
Cheers. Bryan.
