Since I retired about a year ago I have spent a lot more time woodworking in my shop. As I started to spend more time woodworking I went through several different combinations of tools that I carry. I was constantly looking for the right combination to be productive and not misplace tools I set down somewhere in my shop. At the same time I didn’t want to carry more than I needed to. As the tools I carry have changed so has the rig I use to carry the tools. I have used an apron, a tool pouch that clips on my belt and a tool belt. Currently when I am building something I carry the following:
Measuring and Marking:
1. Wiha imperial and metric folding rule. I like using this to measure shorter distances.
2. Paolini Pocket Rule. Use this lots of times a day to set guide rails a couple mm form the edge of plywood sheets, set table saw blade height, setup router table, set reveals, etc.
3. Tape measure. Typically something 5m/16ft long and without the wide blade.
4. Starrett combination square. My go to for checking boards coming off the planner / jointer
5. Mechanical pencils. I carry both .7mm and .5mm
Misc Hand Tools
1. Stiletto 10oz trim hammer
2. Eastwing 12oz rubber mallet. I use this to better align boards before glueing or fastening
3. Couple nail sets.
4. Extra bits. I carry a Centrotec T15 and T25 bits to drive the GRK screws I use on most projects
5. Utility knife which in reality does not see much use except opening packages, tubes of chalking, breaking down boxes, etc.
Misc.
1. Remote for my dust collector
2. Small bottle of Titebond III
3. Couple types of fasteners
4. Collins miter clamps and tools if working the miters
I have started to carry all of this in a tool belt. Specifically a Badge Bags Carpenter tool belt with side by side fastener pouches. The belt is comfortable and provides good back support. Tape measure and pencil access are great. I very much like having hammer sleeve for the rubber mallet and hammer loop on the back for the Stiletto. This is especially helpful when installing the cabinets, book cases, or whatever else I have built and am not in the shop. Two ouches for fasteners is something I use way more than I thought I would. I like the size of the pouches and the “compartments” for individual tools. After a little personal training to put stuff back in the tool belt instead of setting it down somewhere I find I don’t misplace tools as much as before. Finally this setup is great when I am helping others outside the shop or working in my own house (shop is a separate building on our property).
When I have a bunch of sanding to do I switch back to an apron. Probably the only time I will use a tool pouch moving forward is if I am going to someone’s house to take measurements for a specific project.
So, what are you carrying and why?
Misc Hand Tools
Misc.
