OK I guess the one need I have is a sander, My lousy Dewalt is on it's last leg again. I can't believe I wasted money getting it fixed once already. That was less than a year ago.
What's the biggest difference in the 5" sanders? Would the CT MINI Dust Extractor be enough for my home shop?
Thanks for the help so far guys, look forward to more info.
Gary
Gary,
Not sure what you mean by the MINI being enough for your shop? Do you mean having enough suction to handle the Festool tools or for that as well as shop clean up?
The MINI was designed primarily as an installers' vac - cord and hose store in the top section and light and easy to pick up and carry to and around the job. This doesn't mean that it can't be used in the shop as the primary vac - it sure can. And i smore than enough vac for the majority of Festool tools. Having said that, I would opt for the CT 22 or even the CT 33 - they have a much larger capacity, greater suction and offer the option of using different hoses.
Due to it's lower maximum suction and non interchangability to a larger diameter hose, the MINI is not offered as part of a "package deal" with the OF 1400 and 200 routers, HL 850 Planer and TS 75 saw.
