Where can I get this style of hinge?
JonathanJung
In pursuit of making a completely hidden hinge for an upcoming project, I've come across these:
https://www.ironmongerydirect.co.uk/search?query=casement pin brass
combined with some bushings it should work for my application. Ideally the mounting holes would be slotted to allow for side adjustment. However, the only suppliers I've found are in the EU/UK.
Is there another name or application for these, so that I have better luck finding them in N. America?
Find a local machine shop to make them for you. They wont be cheep, but should not break the bank.
I agree that this is a "pivot hinge" but there are so many different solutions to this problem that you will have to decide which one will work best.
A quick look at the images will probably help: https://www.google.com/search?q=pivot+hinge&client=firefox-b-1-d&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjQs6_oyMr1AhU9jokEHQ66B5QQ_AUoAnoECAEQBA&biw=1600&bih=775&dpr=1
The first time I came across those it struck me as an odd name. Don't most hinges have a pivot? Is that not the point of a hinge? Pivot = fulcrum. The only difference is that this pivot is in the center of the door, rather than off-set like a typical leaf hinge.
Concealed hinges have multiple pivots and the actual fulcrum is not clearly defined because it floats as do Soss hinges, but those are the exceptions.
The real thing to be aware of with hinges like these is that the part of the door that extends past that pivot point will swing in the opposite direction of the rest of the door as it is opened. The thicker the door and the further the pivot from the edge, the more of a problem this becomes. That is the point of the "Knife hinges. The put the pivot far closer to the edge, reducing this effect.
Functionally, I don’t understand the reason for pivot doors.  You do end up with less stress on the hinge than an edge-mounted hinge would have.  And you can end up with a visually larger door.  But the actual ingress/egress space is going to be less than the width of the door.  So what’s the point?  (Other than aesthetics.)
I mentioned having these fabricated. I am in the process of building 2 “hidden” door bookcases. For this application I had to fabricate the pivots. The axles are slip fit.
One of the pivoting cases has 2 file drawers in it, loaded the thrust on the pivot is ~1500 pounds.
