My wife and I bought a 50's Jewel travel trailer and want to refinish it and convert it into a concession stand. The metal skin on the outside has a pattern of shallow ridges every few inches, as you can see on this similar-looking trailer:
We've gutted the inside and she's started sanding the outside. At first she was using my Bosch 5" oscillating sander, but she kept pressing on the corners which stopped the sanding pad from rotating and melted the velcro loops. The sander just wasn't aggressive enough, even with 40 grit paper. Then she switched to my oscillating multi-tool's sanding pad, but that hook-and-loop pad burned up really fast. Since we're keeping the trailer at a friend's house in another town, we don't get over there very often, so I want to be able to make a lot of progress each time we go over there. I just bought an ETS 150/3 for woodworking, but I assume that isn't the right sander for removing the old paint. I was thinking about either a Rotex for its aggressive mode or a linear stroke sander to get into all the ridges and grooves, but I'm really not sure which one would be best and I can't justify buying both at this point, even at reconditioned prices. Which sander would you recommend, and which backing pad(s) and paper will work best for this job? Also, are the Festool pads more heat-resistant, or are we going to burn through those, too?
