I have a need to have a track saw for work (I currently have a TS55 for home use). I am cutting aluminum honeycomb core product and the length is around 110" (longest). Right now, we are using a straight edge and a razor blade. That's just not cutting it (no pun intended) any longer. The thickness is irrelevant as it's well within the limits of a TS55. However, I'm wondering if this is a good case to use a TSC55 or a TS55? The material in and of itself is rather flimsy, but it is on a shop made cart that has a sacrificial top that we could cut into, so it's fairly stable. If you think this is a good case, what would be a good blade to try with? I'm thinking of bringing my TS55 here to try out the process, but I only have wood cutting blades...
Thanks,
Kevin
Thanks,
Kevin
