I was squaring/straightlining some stock using my table saw yesterday when it occurred to me that maybe it's not that obvious a technique.
The longer the fence the better.
First pass with the concave side against the fence.[always put the concave against the fence]
Second pass with the newly straightened and flat side on the table.
You now have a face side and square edge.
Next move to the thicknesser and plane off the opposites to you're face side and square edge.
Then reverse to plane you're face side and square edge.
The advantage is you can remove a lot off material quickly [even if you have a jointer]
Obviously you're limited to 'jointing' the height of cut of you're tablesaw.
It's a very quick way to get straght lines and square edges but if you're in the habit of checking you're stock with an electron microscope then maybe it's not the right tecnique for you [unsure]
For clarity,when I say jointer I mean a long bed planer where the wood passes over the knives.A thicknesser is a box the wood passes through pulled by rollers and it does what it's called.
[attachimg=#]
[attachimg=#]
