Zaphod said:Just curious if any one knows why Festool omitted the brake for the U.S. market. We get the TS55EQ rather than the EBQ variant.
Zaphod said:The lack of a brake is unrelated to the 110/220 voltage difference. I'm assuming it was some esoteric UL red tape.
joiner1970 said:Zaphod said:The lack of a brake is unrelated to the 110/220 voltage difference. I'm assuming it was some esoteric UL red tape.
Dont just brush my comments away with out an explanation.![]()
How do you know its not because of the voltage difference if you look on the UK version as I said the 240v has a brake and the 110v does not so surely that has nothing to do with regulations or laws as the 240v version does have a brake here in the UK.
I think you hit on it - the 110 (higher amperage) versions would have some problems with the brake, whereas the 220 motors would be able to handle it. Exactly what "stresses" a brake places on the motor or switch, I am not sure.
Bob
Zaphod said:joiner1970,
Still not sure why a succinct and accurate response riled you. I'll make a concerted effort to respond to your "What none of you have seemed to notice...." posts with more verbose phrasing to avoid winding you up.
Don't get your feathers ruffled over your perceived brushoff, none was intended. I have(had) a PC router, Bosch router, Bosch SCMS, and PC circular saw which all run on 110 volts, draw 12-15 amps, and have motor brakes which stop the blade/bit in about one second. Equipping a 110V tool with a brake is not uncommon and surely not beyond the engineering gurus at Festool.
