Width of TS 75 relative to TS 55EQ
I currently have a TS55EQ and I am building an MFT Cart.  I have figured out that if I build a shelf 250 mm wide, I can store my TS55 EQ on the shelf to get it out of the way.
Does anyone know the width of the TS75 at it's widest dimension including when the zero clearance insert is attached?
It occurred to me that one day I might buy a TS75 and the shelf should be wide enough for either saw.
Also, what size Systainer does the TS75 com in?
I have both but have no clue on the width, presume they are alike as they fit the same rails.
I do know the ts75 comes in a sys5
The TS55 motor protrudes over the track some, so the TS75 may protrude a little more or maybe it is the same.
The TS75 can't be too much wider since the width of the systainer 4 and 5 are the same.
Then again, the zero clearance insert is added after the saw is out of the systainer.
I don't have much room to make the shelf too much wider.
Yes, the TS75's motor housing does stick over more to the left of the rail than the TS55. I used to have this stored in my memory banks, but have since made a few withdrawals... As I recall, the TS55 hangs about 5/8" over the left hand side of the rail, while the TS75 is more like an 1-3/8" over, or something like that.
