Get the AC, it is a small cost adder but adds a significant capability.
One advice, go with the CT26 AC version and get a Cyclone to go along from the savings. Be it a CT-VA (recommend) or other. For non-professional use the CT36 is just huge and heavy when full. When filled with drywall dust, it gets easily to 200lb weight.
CT26 with a cyclone will last months on hobby or light commercial use. The bigger bag capacity is an overkill then. Plus it allows more systainers put atop, into the "saved" height.
EDIT: Just noticed CT 26 AC is NAINA at the moment and the 36 is only in the "Planex" setup.
In the US context, I would go with the CT26 and expect to borrow an AC vac along with the Planex (they usually rent it like this anyway). Use the saved money to get additional D36 3.5m hose and a CT-VA cyclone.
If you do go with the 36 AC, some advice below:
Do not plan/expect/use AC for wood dust. It is for concrete, drywall, etc. which produce fine dust that would clog the SelfClean bags. It is no good for wood as the wood fibres would clog the the main filter instead - AC cannot get them out effectively.
With an AC vac, you will also want to get another main filter eventually - use one with bags and one bag-less. Once a main filter is used bag-less it is not a good idea to return it to "bag use" as it will never work as good.
