Woodpeckers MCS-075X2 - Miter Clamp Set 1/2" -3/4" Thick -
Here's a trick solution to clamping a miter; two mating blocks requiring only one clamp to provide equal pressure on four surfaces simultaneously. Like the Woodpeckers Clamping Squares, the Miter Clamp Set is machined to a very tight tolerance from solid billets of aircraft grade aluminum to ensure a perfect 90 degree angle. At 1/2"- 3/4" thickness, these stout, sturdy clamp jaws are robust enough for use both independently with virtually any clamp or as part of a clamping fixture.
Approximate dimension, 3" x 3" with a jaw length of 1-5/8". Anodized surface will not oxidize when in contact with water based adhesives and cleans easily.
Price $35.00 for all three.
$5.00 shipping. PayPal payment
