- Sep 21, 2022
Get it while you can! The Woodpeckers AutoAngle Drill Guide is a one-time ONLY offer you can't afford to miss!
In short - this tool will change the way you drill angled holes. How?
Drilling angled holes can present quite a few challenges. From setting the correct angle and direction to pinpointing the perfect entry point - the complexities mount up, especially when you're working in the field or on a large workpiece.
Woodpeckers' AutoAngle Drill Guide takes the guesswork out of this task! It combines the top-notch features of their AutoLine Drill Guide with an innovative protractor base. The result? An intuitive and efficient way to set up your drilling angle and hole location.
With Woodpeckers' AutoAngle Drill Guide, if you can lay out a crosshair on your materials, you can put a hole through that crosshair at any angle, from straight up and down to a 40-degree angle. It's that simple and precise!
This tool is available for special order ONLY until July 21st. Get it before it's gone!
