Woodpeckers Phenolic Corner Clamping Sets - PCCS
Jason.L.Hagen
Apparently I ordered this a long time ago and never used it. Just found it in a box of stuff. I know how to use the large piece. It can either go inside or outside to hold stuff at 90 degrees while the glue dries. But I’m curious how you use the triangle piece with the L shaped piece. Maybe I’m over thinking this. Hopefully someone else has these and can demonstrate how they are used to be used.
Look at the flat spot in the top of your image-
Clamp diagonally across the joint, from that little flat spot to the hypotenuse on the triangle piece.  In this image, clamp would be dead vertical.
Oh yes, I see it now! I do not know why I didn't see that yesterday.
