Woodpeckers saved the day holy rail extention
TheTrooper
I was building some shop cabinets and realized that my rail wasn't long enough for shelf pins.  Then I thought that my Woodpeckers DF500 outriggers and flip-flops had a T-track and my rail had a t-slot.
I drew a centerline on the panel and the rail and slid the flip stops at each end of the panel. Problem solved, I know it's gehtto but it worked. [smile]
[member=47595]TheTrooper[/member] - actually that is an inspired setup. WP should market a set of those extrusions as "t-track extenders", albeit they would have to anodize them in chartreuse to promote wide adaption.
Great idea.
RMW
Richard/RMW said:
[member=47595] WP should market a set of those extrusions as "t-track extenders", albeit they would have to anodize them in chartreuse to promote wide adaption.
I was on the phone with them today and requested the same thing.
Needed to join two Story Stick Pros (which use the same extrusion).
Nice fix, I've done the same with 8020 10 series material.
