HowardH
- Jan 23, 2007
I decided to go back to basics and build a fairly easy cutting board to make sure my technique was sound. I had been have trouble getting the corners to line up when every other strip was flipped. I was scratching my head and then I discovered my table saw fence was toed out about 30 thousands! [scared] Once I got my fence back in line with the blade, that cured that problem. The difference between this board and the one Marc shows is I added the juice channel. I was going to use my MFS but I only have the 400. Not for long. I asked Santa for two 700 profiles and that will solve that problem. In the meantime, I made one up using MDF and it worked fine but it's not adjustable.
[attachthumb=#1]
[attachthumb=#2]
[attachthumb=#1]
[attachthumb=#2]
