Ok, thinking about adding a bandsaw to my small (but growing) collection of greenies. Much of the cross cuts will be taken care of with a TS55 and I would like to have extra space in my garage so I'm discounting the table saw route. With that in mind, I'm considering a bandsaw and the two that are on the top of my list is either a Jet or Powermatic. I would get their "deluxe" model so that means it'll have the riser block either in place or will be included as part of the purchase so that will give me a resaw capability of 12" on both models. The price different is about $150-200 with the Powermatic being the slightly higher cost, but if the Powermatic is clearly a better choice, I'll go for it. If it's all about equal than maybe use that savings for an extra set of blades or something instead by getting the Jet.
Both comes with 5 yea warranty. Powerwise, the Jet is 1.25 HP and the Powermatic is 1.5 HP. The Jet's lower cabinet can be used for storage and the Powermatic one can not, but it has a lamp while the Jet one does not. Oh a third choice is a Rikon and that's another 100-200 cheaper than either of these two, but it gives me pause with their more limited 2 year warranty.
Given all these things, I would like your opinion about these two bandsaws in terms of ease of use, setup, maintenance, support, replacement parts, limitations, and whatever else you want to volunteer. Pelase share your thoughts on the brand, reliability, quality, etc...
