I have a Festool 1400 Router mounted in my Festool Router table. I have been buying Sommerfeld Router bits and some of them are 2 piece sets, so after you run one of them the other is set to match the 1st one. Mark Sommerfeld said the best way to achieve the right setting is to install a rubber grommet into the bottom of the collar to assure the right height each time you put a new router bit in the router. I know you are supposed to raise the router bit a little off the bottom so it is free spinning, and this grommet is supposed to do that and give you the same setting each time. Do you recommend doing this?
