I have just started planning the construction for a bedroom renovation for my daughter, where the design has been done by an interior designer friend.
Part of the design is a set of large drawers (drawer area = 1000mm wide x 700mm) directly underneath a platform area (ie another piece of 18mm plywood on top) upon which people (1 at most) are expected to walk over or sit upon (or kids will probably jump up and down on).
I was wondering if it would be sufficient to construct a basic 18mm plywood carcass for the drawers (top dimensions 1000 x 700) and would this be strong enough on its own to support the load above it without sag / bounce / flex / breakage? It is likely that the platform could also rest on a bearer that is dynabolted to the wall to distribute the load if this helps add some context to the situation.
I am guessing that if it is not strong enough I would either need to:
1) increase the thickness of the plywood (any suggestions?)
or
2) construct a load bearing frame (which would not be visible) around the cabinet carcass to support the platform above it
As always, thanks in advance for your helpful suggestions and experience.
or
