36 mm Hose to Midi 90 Fitting
m8
My apologies if I have missed the obvious but I am looking for a 90 fitting to go from a 36 mm diameter antistatic hose into my Midi.  Also if anyone has experience with the 32/27 mm tapered hose, item # 500680, I would appreciate to hear how well it performed with routers or other large chip/dust producers.  Thanks
That fitting does not exist. I simply put my 36 mm hose in my Mini & Midi, no problem it sticks out from the top. If you really want to have a 90 degree fitting I'd buy the standard 90 degree fitting for the 32/27 hose and modify it to accept the 36 mm hose.
The 32/27 hose will work with the big chip producers like planer & router, but is not ideal and willl often clog at the nozzle.
Thanks Alex!  Your info on the tapered hose save me money and frustration.
