woodbutcherbower
- Apr 25, 2021
Hello all,
I have a TS55 and an OF2200 which I've been using for years with a CTL26 and a 27mm hose. Since adding a CT-VA-20, the suction has obviously reduced a little - plus the 27mm hose is far from ideal when it comes to vacuuming the floor after work, using the standard plastic cleaning set - the slightest chip or shaving seems to block the nozzle where the hose end couples up to the plastic tube.
So I want to upgrade to a 36mm hose. Just a coupla questions before I order;
1 I'm confused by all of the available options - is part no. 204924 (D36 AS/CFR - 3.5m) the straightforward 36mm replacement for my existing 27mm?
2 Will this new hose be plug & play? i.e. will it just slip over the outside of the tool nozzles and cleaning set tubes rather than squeezing down the inside of them? Or do I also need some kind of adaptor?
Thanks in advance, your help is appreciated.
