3D Printed Aftermarket ETS EC 150 Edge Sanding Guide?
Hi, these have been out a awhile.either@90 or 45 degrees
It arrived yesterday. Seems decent, but a couple niggles:
1) Since it's 3D printed, the reference surface that goes against the stock face isn't smooth and will scratch soft materials. I sanded it down and attached some HDPE tape to the face.
2) I got the stand that enables the sander to be used as a stationary disk sander. But, the attachment doesn't lock into the stand and can easily rotate (which is how you remove/install it). I could probably drill a hole for a grub screw to lock it in place, but it's a bummer.
That all said, it attaches pretty easily to the sander, seems secure, and work to hold the sander for edge and similar sanding.
[attachimg=2]
[attachimg=3]
[attachimg=4]
