[3d_printing] - anyone come across cleantec sleeve stls?
tofu
I purchased the OEM cleantec sleeve (Festool 202346) to put on my older Fein hose, which measures 1.58" OD diameter. 1.58" was what some fella on Amazon said the ID of the festool sleeve was, so I thought I found a great solution. Unfortunately, that 1.58" ID measurement didn't account for the retaining clip and screw on fitting, which are much smaller!
Like a donkey, I cut off the tip of my vacuum hose already, so I'm at the point of no return. I was wondering if there's a STL file available with a similar "screw on" and locking clip configuration. I'd like to print it from TPU so it's soft and rubbery like the festool one. Even if the stl is not the correct size, maybe I can scale it.
Thanks!
