5 minute version of Dado jig
Crazyraceguy
I'm sure that many of you have seen the one made by Marc (TWW) or the even more elaborate version from Woodpeckers, but sometimes in a "one off" situation, a job-specific jig will do just fine.
Yesterday I needed to make a dado to fit a metal U-channel, as a decorative item, in the outside of a column. The outside was pre-laminated so the dado was just formed by spacing the parts away from each other. Where the edge meets the other side needed a matching groove.
Those bigger jigs are intended for larger projects and not easily adapted to a vertical surface.
5 minutes with some short strips of plywood and 1/4" mdf, custom made for this application. Since the face they were going onto was raw, a couple of 23ga pins told hold them while adding some screws, worked fine. They could also be double-side taped, but there is some risk there.
The first time I made this trim feature, for a different location, it didn't have this detail. There are more of these to come, so I kept these pieces after the cut was made.
I make lots of jigs/fixtures/forms that only ever get that one-time use, so I usually just throw them away. Since this may come back, I'll hold onto it for a while. I have learned over the years to write what you need to know to use it though. Copy-ring size, bit size, reference edge, brand/model # of the thing it fits, etc. It is very easy to forget.
I made this for my OF1010 with a 15mm copy-ring and a 1/4" bit, marking the left and right "just in case". It shouldn't really matter because I always use the Festool centering cone, but why not. I marked them after successful use. Jigs don't have to be fancy, adjustable, or permanent, just useful.
