Rick Cabot said:Hi Brent
We have used the Klingspor 5" and 6" discs on our Festool sanders and found them to be very good. However, the vast majority of our sanding paper is still Festool as it is easier to acquire in our area. Note that their paper does "contain" Aluminum Stearate. See page 21 of their most recent catalog or go online at www.woodworkingshop.com. Hope this is helpful.
Regards,
Rick Cabot
Maine
Michael Kellough said:I don't think aluminum stearate is used on abrasives. Zinc stearate is used on abrasives intended for sanding finishes as it helps prevent loading of the abrasive.
The reason to beware of it's presence is that it can cause fisheyes and other adhesion problems if you later apply a water based finish.
If you think your wood may be "contaminated" with zinc stearate and you want to use WB finish just apply a first coat of shellac. Target even makes a WB shellac that does the job.
