The reason it's seldom set up this way is also because the fence will significantly overhang the edge of the table. Also, the fence is held in place in two positions, and if you use the rail lengthways, the two positions will be closer together and provide less rigidity and hence less accuracy.
It will become more obvious when you get your table.
Enjoy it when it comes!
