DIY WoodWerx
- Mar 31, 2017
Made a set of parallel guides out of 80/20
https://www.woodworktech.com/home/diy-80-20-parallel-guides
cubevandude said:They look pretty nice. Any chance you can supply a list of part numbers you used?
Whats the total cost of that parts list?DIY WoodWerx said:cubevandude said:They look pretty nice. Any chance you can supply a list of part numbers you used?
(2) 3356 - used to attach guides to rail
(2) 4165 -
(2) 4167
(2) 2012 - 24” length
ben_r_ said:Whats the total cost of that parts list?DIY WoodWerx said:cubevandude said:They look pretty nice. Any chance you can supply a list of part numbers you used?
(2) 4165 -
(2) 4167
egtlover74 said:What kind of screw is the chrome thumb screws? They look awsome. [cool] I was just looking at seneca jig for $120 plus dollars
GoingMyWay said:Nice looking parallel guides and for a very affordable price. Correct me if I'm wrong, but it doesn't look like you can make any cuts narrower than the the width of the track. Is that correct?
Richard/RMW said:Somewhere I have an old rip guide setup doc that shows how to create a spacer of the same thickness material as what's being cut to let you cut stock narrower than the guide rail.
All you do is set the stops tight against the guide rail bracket & then cut your spacer material. Next move the stops left to the width of the part you want to cut and using the spacer cut your stock. Presto, narrow stock guide, save the spacer for later use.
Will try to find the setup guide and post it.
RMW
PS - nice job on the guides, I like that they are totally DIY and don't require any machining.
DIY WoodWerx said:Richard/RMW said:Somewhere I have an old rip guide setup doc that shows how to create a spacer of the same thickness material as what's being cut to let you cut stock narrower than the guide rail.
RMW
That would be cool. Thanks
Richard/RMW said:Found it. Geeze I've got a lot of junk on my computer.
Now I recall this started as a calibration cut & then I realized I had made a spacer. Hope it's of some use.
RMW
