Bugsysiegals
- Mar 19, 2016
I’m building several 24” deep mobile cabinets for tool storage and then planning to build a few workbenches which the cabinets will roll underneath. The workbenches will have MDF tops with Parf Guide drilled holes and I figured I could do some clamping, sanding, and align the Kapex deck so they’d also serve as a miter station.
I was planing to make the workbenches with 8020 but I’m now considering whether it makes more sense to build Paulk style bench tops which sit on top of 2x4” framing. My thoughts are that they could be lifted off the base and set on saw horses for breaking down 4x8’ sheets and then placed back on top of the base when finished (perhaps can be re-aligned with some dogs on the bottom MDF). In addition, assuming these would be 30” deep, I could also use them as a MFT style cutting station using dogs with rail clips which could even be taken mobile in the future.
I love the idea of keeping things lean, reusable, flexible, etc. Maybe I’ve not searched enough but haven’t seen any other posts of anybody else doing this so I figured I’d create a new thread and ask your thoughts. Are these tops fairly sturdy, remain square, etc.? Does this sound like a better solution than 8020 which is more of a one trick pony?
