sancho57
- Jan 13, 2011
Hi guys,
When I use my planer to clean up saw marks etc I alway end up with a taper especially when I use it to clean up the edges with the bench unit.
when I free hand it I use the accessorie full length fence not the one that comes with it.
Im sure its in my technique. Maybe Im putting to much downward pressure on the rear handle. Not sure.
So what is the best technique to do what I want which is to clean up the edges/ joint my stock using the 850 rather then a full jointer, and using the 850 as a jointer using the bench unit.
thanks in advance
thanks in advance
