Can Festool replace my jointer?
Boards were being jointed before either machine was invented.
Yes. Hand plane. I had to joint two boards uising a hand plane to pass my wood shop class. We had access to a really long plane, probably around 2 feet long, so not as hard as with a shorter plane. But not easy and was time consuming. I assume that with practice it becomes easier and faster.
I’ve been successfull jointing boards as long as 4’ using just a table saw. I simply cut one board and the second board on the opposite side of the blade. That will guarantee that the angle of the blade does not affect the fit. But you need to start with a straight board and your technique has to be good, or use a couple of feather boards to hold the boards against the fence.
You will have to mark the boards with pencil marks showing the correct assembly or you will end up confused and getting the fit right will drive you nuts.
I assume that you could do the same with a track saw. Cut one board with the right side of the blade and the mating board with the left side of the blade. I’m not sure how much technique affects the straightness of a cut on a track saw. But I believe, that for shorter boards this would work.
Note: The thickest I have used this technique on is 1-1/4”, so this applies to (probably) 3/4” to 1-1/4”, but likely to a bit thicker.
The plane you used was likely a jointer plane, the longest one in the usual family of planes. Many traditional woodworkers don't have one and would use a low angle jack instead. Paul Sellers often uses a #4 to do it.
To make life easier, some learn how to plane two boards together by bookmatching, standing and clamping them in a vise. Or use a plane with a fence:
With that jointer plane, the only issue was maintaining perpendicularity to the edge. That turned out to be more difficult to achieve than to write about. It took me one entire class (45 minutes) to joint two boards. I would imagine that a machine jointer would be quicker. I would also imagine that one with a nice long bed would be better than one of those benchtop versions.
I would say that after jointing those two boards, I felt more like a real wood worker than anytime since. There was a good deal of satisfaction derived from that process. Especially nice was the long curls of wood peeled off with each pass. With each pass of the plane I had to get out the square and check. Checking tool more time than planing.
And that jointer fence, if it worked like it appears, would have been a great help. I would think that it would have to be wider to be really effective though.
Veritas fences (including variable or BU) are 11" long, long enough for squaring edges.
Paul Sellers?!?!?!??
With definitely the exception of Derek, I think many of us (at least me) have difficulty reaching Rex Kruger level of hand tool accomplishment - and you introduce Paul Sellers... With that bar, might as well give up hand planing altogether now! :p
As Packard pointed out, with practice, [jointing] becomes easier and faster. Paul Sellers certainly wouldn't want you or anyone to think that handplaning is an insurmountable task, After all, the exactly opposite message is what he is trying to spread through his teaching.
Paul Sellers removes the tiny gap in the middle in the video. But some would leave it there:
I looked for, but couldn’t find a clip of “Book” (Harrison Ford) after he was on the mend on an Amish farm, building a replacement birdhouse for the one he crashed into.
He was hand planing a plank, and he looked like he was a real woodworker.
((The barn raising scene, and especially the music by Jare, are among my favorites. I’m going to find that clip and post it.)
Found it. (But could not find a “Building the birdhouse” scene.)
Ford was a real carpenter before he was able to make a living as an actor.
In my never ending quest to eliminate my large tools, I've successfully killed off my table saw and router table, now my sights are set on the jointer. I already use a TS55/75 on longer boards to edge join, but I do make small parts too, though not as much. I have the HL850 but it's too large to edge joint small things that the track saw can't do. Any chance that smaller planer (not in the USA yet) might be what I need? Anybody successfully get rid of the jointer?
The small power planers are only for smoothing and straightening an edge. Jointing is done in three dimensions, not two. If not a machine jointer, then a tablesaw or possibly a tracksaw, but the best way is a jointer hand plane ...
I think a jointer is critical for getting a flat face. Yes, you can use planes (lots of work and slow) or a router flattening devise( slow and very dusty) or a sled for a planer (also slow). So I guess the question is why? Can it be done, 100% yes. But unless you have no space, I am not sure why one would go that route?
For me, I'm trying to get to a point where I can set up the wood shop equivalent of a camp kitchen. The ability to make almost anything anywhere.
Here's a new video from Festool UK on the HLC 82:
Had a play with this today, absolutely sensational planer, I'm adding it to my list for sure. My mate was there today and was so impressed he's already ordered one to pickup on the way home.
Super quiet, and hooked up to the dusty almost zero dust from a 1mm DOC on 40mm wide super hard Aussie timber with no effort. The result was good enough to skip sanding and put the finish straight on!
Nicely balanced too!
I agree, the ergonomics are fantastic. I wish they would add the rustic planing heads as accessories for it.
That was one of the questions I asked but the rep had no idea. It'd be great if Festool released one.
I'll definitely be getting the chamfer adaptor for it. That's really handy for beams and posts.
The custom heads on the HL 850 are enabled by the special side-mounting of the head. There is no way to put a easy-to-swap custom head on a traditional-design planer like the new HLC.
I second those that it should have been a cordless HL65. Though that may still come. The HL65 is a prime candidate for a cordless-only tool if anyone asks me, so refreshing it such would be very much logical.
This one seems -repeating myself- geared for the "mainstream" market, same like the new jigsaw, the DTSC 200 etc. It does not compete with the use cases for their existing planers. It expands on them.
Couldn't agree more, I totally get why they released it in this guise, but a HLC65 would definitely have been more appealing to me.
