mouppe
- Feb 7, 2010
LN or LV is not an either/ or choice. I prefer the LV router plane, spokeshaves, shoulder plane and plough plane but I prefer the LN bench planes.
I don't have any skew or fishtail planes and don't miss them. I do, however, have a 1/8" LN chisel to get into the corners when I need to. I think I may grind an old chisel into a skew shape one day.
There's no "best" block plane- just what you yourself prefer. As I said before, I like the LN 102 and have a low angle and a standard angle blade for it. I use my LV Veritas adjustable block plane for the crap stuff like plywood!
Likewise, a smoothing plane is an evolving choice. I started with a #4 because what I read pointed me in that direction, but over time I have come to prefer a 5 1/2. Now I use my #4 for general bench work.
I use my LN low angle jack on a shooting board, for preliminary board flattening, planing a straight edge when the board is not that long, sometimes for smoothing on softwoods...but I would have bought the jack rabbet if it was available at the time. Then again, I would go for the LV jack rabbet over the LN jack rabbet...more features.
At the end of the day, these hand tools overlap each other a lot, so much comes down to the way you prefer to work. Sometimes you just reach for the nearest tool because it's the only sharp one left.
