If you only want to stock one type of paper, go Granat.
Granat lasts 4x longer than Rubin, 2x longer than Brilliant 2, about the same as Cristal. It was developed by Festool to suit the new VOC compliant finishes that are mandatory in the EU. With older finishes, Brilliant 2 and Grant perform about the same. With the newer VOC compliant finishes, Granat has the edge.
Granat is a hybrid abrasive comprised of hardened aluminium oxide with a ceramic grit (the grit is possibly only in 120 and below - I've never been able to confirm that for sure) that helps it stay cooler resulting in less material loading of the discs and a surface that stays sharper, longer than the aluminium oxide of Brilliant 2. It's a stearated coating, but it doesn't contain wax so there are no issues with water based coatings.
Granat will last longer than Rubin, but has a thinner backing material and produces a more aggressive scratch pattern. If sanding a lot of corners or edges that may tend to snag the abrasive's sheet, Rubin would be less prone to tearing.
Granat is also good for sanding drywall/plaster because it clogs less than Brilliant 2, so lasts twice as long.
The only real disadvantage is the cost (Granat is more expensive than some of the other options). Put that to one side, and Granat is the go-to all round star performer if you don't want to stock multiple types of paper in multiple grits. It's the only paper I have for my sanders.
