Woody Knotsensplintah
- Apr 2, 2019
We almost always use oil-based polyurethane spar varnish in our DIY projects.
Previously, with free-standing cabinets, we have gone the whole route of 6 coats of hand-applied varnish with sanding, etc., and then a full round of hand polishing with compounds before waxing.
Our current project is a set of wall cabinets, and we are hoping to shortcut the finishing process as there is a lot of surface area, and the cabinets are for utility in a pantry/storage room.
Another challenge we have is the pervasive presence of dust. We are varnishing in a spare bedroom temporarily converted to the paint room because the workshop is not heated. The house is clean, and we clean the wood by brushing, vacuuming, hand dusting, etc., but the glossy finish still has specks of dust. We live in the southwest desert; the dust is in the air.
Each time we sand, the dust smooths right over.
For the shelves, we are at three coats with a fairly even glossy finish that we would normally level with 600 grit. But, I hesitate because I suspect when we are done, we will feel obligated to add yet another coat due to the minor unevenness revealed by the sanding process.
For the doors, we intend to go through the full process.
I am writing to ask if anyone has suggestions for processing the shelves. Is it possible to get an even appearance with a final finish when the coating has not been adequately flattened?
Can we fake it by jumping ahead to hand polishing?
A nice, even finish is all we want. We are not necessarily hoping for a high gloss.
Thank you.
Thank you.
