Adding a switch to SysLite Duo
nclemmons
Bentonville, AR
Quite a few here have wished the SysLite Duo had a switch on it.
I added this switch -
https://www.amazon.com/gp/product/B00826P0AO/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
and it works well.  I looked at several and this one supports up to 6 amps and had the best reviews on Amazon.  I think the SysLite only draws perhaps 1.5 amps, so plenty of overhead.
It is a simple install requiring the switch installed in-line to the black hot wire.  There's room in the switch for safely routing the ground and common wires.  I used a Dremel with a deburring bit to slightly enlarge the hole in the ends.
The switch includes interior clamps on each end that securely clamp the wire to remove any stress from potential strain.
Took about 15 minutes to install - measure carefully when cutting the insulation as you only end up cutting into the black wire.  The other two are kept intact.
neil
