Adhesive advice sought
I’m happy to report that a second attempt with JBWeld ClearWeld epoxy has been successful. This time I carefully titrated the epoxy components using a scale that measures to 0.05g and applied a thin layer.
Thanks for all the suggestions.
It's not helpful in this particular case, but for later when someone finds this by searching, it might.
The reason it wouldn't work here is that is not clear and would show through the glass.
For other applications though, we have been using some stuff called Boa-Bond. It comes in standard caulking gun sized tubes. This material is very thick/stiff, thus hard to dispense, but it sticks well and very quickly. It's not like superglue or contact cement, but it does hold surprisingly fast.
It's similar to your typical construction adhesive, but holds fast much quicker, doesn't drip or run, and sticks to a greater variety of materials.
