Adjusting blade tension on scroll saw.
Packard
I just got my first scroll saw, as a way to use my small scrap pieces, and to spend time in the shop seated to spare my bad hip.
I got the Wen unit, based on satisfactory reviews and low cost ($130.00).
But I need some guidance on how tight to tension the blade.  How do you determine that?
Note:  The only local store carrying blades is Harbor Freight.  They included one of each in five different tooth counts.  I am currently trying to saw 3/4” pine.  What would be the suggested tooth count?
And while I was at H-F, I saw a 16” Central Machinery scroll saw (the same size as the Wen saw).  On clearance at $39.95.  I might have tried that if I had known.  If I enjoy the work, I will probably opt for a better saw.
They seem to be about coping saws and jewelers’ saws.  I’m messing around with a motorized scroll saw.
(I did cut George Washington out of a coin ($0.25), with a jewelers’s saw.  But I am not going that direction now.
But thanks for the suggestion.  It looks like they make a very nice product.
Regards,
Packard
Packard,
we have a HEGNER scroll saw which replaced a 1940's vintage ROCKWELL Scrollsaw and has served flawlessly.
Imported by ADVANCED MACHINERY  - here is a link to their Owners Manual.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://cdn.shopify.c
depending on the material you are cutting and the blade thickness and type you'll soon discover a sweet spot for your particular application. You will probably find that on a low priced machine the blade clamps are the limiting feature for blade tension.
On all these type of saws, relax tension when not in use.
Hans
This saw allowa either pinned or non-pinned blades.
The pinned blades can be tightened enough to pop the in two (which I did; and which is the driving force for this thread.
The blades that came with the saw worked fine on 1/4” plywood, but were problematic on 3/4” pine.  They were difficult to count, but about 22 TPI.
The assortment I picked up today included from 10 TPI to 24 TPI.  The count based on the packaging.  I did not verify.
My girlfriend uses a Pegas 21" scroll saw. From what I recall she tensions based on audible feedback when plucking the blade. Kinda like tuning a guitar.
For pinless blades, she uses those from Pegas. Another brand that's very popular is Flying Dutchman.
Thanks for the replies.  I installed a 10 TPI blade last night and that resolved all the issues I was having.
The provided blade was good for 1/4 material but too insubstantial for the 3/4” material.
So, for the time being, I am all good.
Thanks,
Packard
