Advice on Abrasives Needed.
Hi all.
Haven't been postin much lately, just poppin in when i get a sec as often as i can, more on that another time.
One of the things I have lacked is a stock of more agressive abrasives and those designed for paint/finish removal.
I have a few tasks around my own home that will require this and and have added the following items to my current pending order:
492848            Abrasives, 80mm x133mm Brilliant2 P40 Grit, 50
492850            Abrasives, 80mm x133mm Brilliant2 P80 Grit, 50
492804            Abrasives, 100mm x 150mm Brilliant2 P40 Grit, 10
492805            Abrasives, 100mm x 150mm Brilliant2 P80 Grit, 10
494032            Abrasives, 5" Diameter Cristal P40 Grit, 50
494034            Abrasives, 5" Diameter Cristal P80 Grit, 50
What should I use to remove paint on concrete with the Rotex? Is the Cristal in the order good for this should I add some of the Saphir? I figure since the purpose of these is to get to bare wood that once there, I can switch to the Rubin paper and move up the grit ladder that way. Hence why I am not considering higher grits (I do have higher grits of the Brilliant paper already for scuff sanding.)
Thanks for your time!
Michael
Some of the dealers will sell broken packages of abrasive.  You do not need to order only in the package sizes sold by Festool.  Ask your dealer.
On concrete? Saphir.
Sanding on concrete is like rubbing two pieces of sandpaper together. You'll want a strong paper for that.
Alex is correct. I had the occasion to sand a good part of my basement's cement floor last year and Saphir is the best paper for the job. Even for that application; it lasted a long time before wearing down.
Bob
I haven't sanded concrete yet but I've sanded rough, landscaping limestone using saphir P24 and a Rotex 150. Taking a REALLY rough slab about  2' x 4' x 1-1/2" to an even surface that was ready for finish sanding only took about 15 minutes and one sheet, that I used later to take the silvering off a 2x12 piece of cedar that runs all the way across the top of a 2-stall garage door.
At that point, I threw it away, I thought it deserved a rest...
I don't think you can sand concrete very well  ;)  The best way to remove paint from concrete is a RAS outfitted with a grinding cup. You can probably find a cup to fit the Rotex, but the machine isn't designed to work such a surface as concrete. The RAS on the other hand, would blow right through it. I have finished many sq. ft. of concrete with my RAS (grinding and polish) and it is by far the best route other then a water feed machine. I wouldn't waste my time with a Rotex and..........sandpaper?
