Alan Peters ("the Makers' Maker")- Free Viewing or Download
ChuckM
I'm fascinated (as well as inspired) by the works of many of the "old guards" such as Tage Frid, James Krenov, George Nakashima and the like.  I came across this eBook:http://www.jeremybroun.co.uk/ebooks/HTML5/makersmaker/. If you view it online, you can access a video or two embedded in there. Alan had influenced many British highly-skilled woodworkers or furniture makers including David Savage, John Bullar, and Robert Ingham, to name a few.
Alan Peters's saw-cut to saw-cut dovetail approach (i.e. aiming to cut joints that fit with minimal chiselling work) is what I try every time I hand cut dovetails -- with varying degrees of success (hey, I'm not Alan Peters [big grin]).
Thanks for the link, Chuck. I was not aware if the ebook, although I have the video of Alan Peters (I probably have the first copy, since I was in correspondence with Jeremy when he was making it). Alan Peter is certainly one of my inspirations.
Have you seen Rob Cosmans dovetail videos, [member=57948]ChuckM[/member]? He uses the same method, but of course he makes it look so easy!
Although I seldom do dovetails on softwood, but when I do, I always find success with Peters' approach. I suspect that hardwood which I mostly use has less tolerance and hence, the success rate is lower in finishing my dovetails in one take without any follow-up work.
Alan Peters is a legend!
I’m lucky enough to own one of his engineers squares and a king sharpening stone used by his fair hands!
