Almost Disaster
Birdhunter
I am building a dresser… my first. After looking at a lot of sources, I decided to build a “frame” and attach the white oak top, sides, and drawers to the frame. The dresser has to be moved to another home so being able to break it down is critical.
I completed the back frame (60” by 30”) and checked its squareness corner to corner. It was off by less than 1/16”. Pretty good.
I use a cheap door on saw horses as Reference surface. Cheap and extremely flat.
I laid the back frame on the door and the darn thing rocked like it was badly twisted.
I was stunned. Disaster!
I then noticed a white eraser was lying under part of the frame. I removed the eraser and the frame laid down perfectly flat.
Whew!
Whew!
I have done that too. Set something down, move or measure in some different way and instant panic?
WTH? Then take a few minutes to figure out that nothing is really wrong.
Nah that aient a disaster, a disaster is ya bump the door and the dressers falls and hits the concrete....
dont ax me how I know that (more than once)
I think we all have done something like that at one point or another.  Big relief when the object is moved and everything is flat as it should be.
Good to hear it was an easy fix.  Did you decide which slides you are going with ?  I am also curious if you are still planning on using KD hardware.  I would love to learn how that works some day.  My dresser is only 52" wide so still manageable as one piece but 72" could be a heavy beast.
