Count me in on the latest Woodpeckers offering. I love the clamping methodology and the manner in which the rails are attached to one another appears to be superior to the Festool product.
I’ve always had a problem with the Festool rail racking slightly because the fasteners were placed on the outside of the rail. Normally this wouldn’t be encountered, however, because I’ve needed different router groove lengths while using the same MFS setup, I always cut different lengths of wooden stops that were inserted into the MFS aperture. The racking of the rails however made that task difficult.
The clamping method also appears to be an improvement. In the past I’ve had to drill holes in the MFS to screw it down to the material I was routing. Otherwise with the clamping of the MFS, the router body, the cord and the vac hose in a very small area, things got congested very quickly.
