Cheese
Svar said:It's 17.8 mm. It is their super track.
Thanks...
Richard/RMW said:Can't for the life of me figger out why WP insists on making this a OTT. They already stock the extrusion, just whack out a bunch of the custom hardware and throw it on the shelf. Cut/slot/engrave the extrusions as needed for a JIT supply and it becomes a stock item. I'll bet they even farm out the clamping plates and probably plastic parts.
I can understand why most OTT's have that status, too many customized parts to make them mainstream. This one puzzles me.
RMW
Svar said:Nice. They beat me to it. Just as I was going to make my own out of their super track. Two screws per side seems redundant though.jlt23 said:Woodpeckers has a one time tool now.https://www.woodpeck.com/variable-router-jig.html
Bob D. said:You could make a jig and use a router. A 1/4" shank mill might hold up
better than a router bit for multiple cuts in aluminum.
If you had access to an X-Carve or similar machine easy-peasy.
Agreed. Something like mortise cutting jig, end mill, slow speed, small increments. Or one could use MFS, oh, wait a minute...Bob D. said:You could make a jig and use a router. A 1/4" shank mill might hold up
Michael Kellough said:For the DIY version you first have to get the end cuts PERFECT. It's possible to to do that with the MFT and a good aluminum cutting blade but it isn't easy and close isn't quite good enough.
Bob D. said:Michael Kellough said:For the DIY version you first have to get the end cuts PERFECT. It's possible to to do that with the MFT and a good aluminum cutting blade but it isn't easy and close isn't quite good enough.
Buy the track, whatever make/thickness you want in the lengths you need, and put your own slots in it. The ends should be square, at least as square as the manufacturer made them.
Svar said:Agreed. Something like mortise cutting jig, end mill, slow speed, small increments. Or one could use MFS, oh, wait a minute...Bob D. said:You could make a jig and use a router. A 1/4" shank mill might hold up
live4ever said:I'm curious what people think would be the best way to make those slots for the square nuts they sell as part of their DIY kit.
Mr_Mod said:I was trolling the web and came across this assistent-system from Belarus, looks to be an interesting producthttps://assistent-system.by/shop/routing-jigs/routing-f-track sadly my russian is crap but they do seem to have some agents in Europe that sell them.
