JZ Bowmannz
- Nov 27, 2013
Dear FOG members:
I experienced an odd situation, maybe someone out there can explain that to me:
I have a newer TS55 EQ (not REQ) in T-loc that purchased sometimes last year before REQ came out, that came with the 1400/2 with clear strip. I was cutting some 4' long 1/2" plywood last night with Parallel guide (a non-Festool one), and wanted to trim off the factory edge, but didn't like to take the parallel guide off every time.
I have another guide rail that was also 1400/2 but with black strip. I figured I could just use that for trimming operation, and this was when the strange thing happened. The TS55 EQ glide on it loosely, I didn't have the measurement but it would take about 1/4 to 1/2 of turn of the small green wheels to get it with no-play fit.
If I take the saw back to the guide rail with clear strip, it wouldn't glide unless I turn the green wheels the other way about the same amount. That's telling me the channel geometry changed from one to the other.
Is that true? Or it's just me? Thanks for your help.
JZ
JZ
