I guess I may be missing something...
When I need to make an angle cut with 75 using the rail - the angled direction of the blade goes 'under' the rail, not outside. That's fine if the cut is not through - lat's say if I only cut an inch depth out of total two inches thick. But if I make the angled cut cutting off the part then what happens is that the part that is cut off is UNDER the rail itself.
So my question is - is there way to make an angled cut so that the cut line goes not under the rail, but outside? Wonder how other people do this...
Thanks and Regards
Anatoliy
Thanks and Regards
Anatoliy
