- Nov 18, 2010
Last night, I helped a friend cut some joints for a hand rail using my Domino. The rail ran parallel to a flight of stairs, then leveled out at either end so we cut bevels at each end of the 2-1/2" x 1-3/4" hard maple at 17 degrees. I thought I was being smart referencing directly off the stock to set the angle of the fence, but when I cut the mortises, the angle was out by a bit. I attached the right-angle support for greater registration, readjusted the fence, tried again, and was still out. On the third try I got it. Does it take this trial and error to get odd-angled joints, or should I have used the fence scale?
The joint turned out good - nearly perfectly aligned and tight, with a good-fitting Domino. I used the trim stop and it worked beautifully.
