- Feb 8, 2007
here is one that is built up against the wall. the large are in the center is for the tv. I made this unit all in the customers garage as my mini shop except for the doors I did at my shop.
Using the festool system really makes it easy to set up, rip up sheet goods, add the adjustible shelf holes... using domonio to join the pieces together. then using the 1400 for the fluting and other details. and dust collection. 3 days was all it took from start to finish, along with my helper who is my painter, but helps to lug stuff and help out as a clamp !
enjoy
QUESTION: I usually wrap the baseboard around the cabinets as you can see in this picture. sometimes these houses have high baseboard, this one is the 7" 1/4 which makes the bottom shelf about 9" or so off the ground and with a 30" base does not leave much room.... so should I make the cabs lower and use a smaller trim say 3 1/2" or what is your oponion? thanks.
enjoy
