Worm Drive
- Dec 19, 2013
Can anyone tell me the height of the table, on the Kapex?
wow said:You mean the height to the Kapex table if it were sitting on a flat surface? I believe that would be same as the height of a SYS 1 @ 105 mm. Festool designed it so that a SYS 1 could be used as a side support on a flat surface if need be...
GarryMartin said:wow said:You mean the height to the Kapex table if it were sitting on a flat surface? I believe that would be same as the height of a SYS 1 @ 105 mm. Festool designed it so that a SYS 1 could be used as a side support on a flat surface if need be...
It's actually 112mm. The 105mm is the height of the SYS 1 without the "feet" which stack inside each other when stacked together. When placed on the floor, it's 112mm in height.
Benjamin said:wow Seth,
love that you have a vac per station...... very jealous
there should be a amonicon of a guy grooling to choose from lol
SRSemenza said:Just to confirm what Tom said. Yes, the UG (single leg) extensions fit and work with the Kapex on the Kapex / Mini MFT.
wow said:SRSemenza said:Just to confirm what Tom said. Yes, the UG (single leg) extensions fit and work with the Kapex on the Kapex / Mini MFT.
[attachimg=1] [attachimg=2]
Seth, that *almost* looks like a working shop, but it's WAY too clean! (Setting myself up with this comment - ) Where's the sawdust?
[smile]
Peter Parfitt said:The height is 110 mm. I am making a new Kapex mitre station and this is a key dimension. Also if you check the height difference, from the Festool web site, you will see that the MFT3 is 900 mm and the Kapex bench is 790 mm.
shed9 said:Peter Parfitt said:The height is 110 mm. I am making a new Kapex mitre station and this is a key dimension. Also if you check the height difference, from the Festool web site, you will see that the MFT3 is 900 mm and the Kapex bench is 790 mm.
My measurement is the same as GarryMartin at 112mm [huh]
