leakyroof
- Mar 23, 2011
. May be yours is newer than mine?rljatl said:.leakyroof said:. I covered this in my review at talkFestool on the K5. Quick and cheap solution was to use the K4 dust port, which is fixed and won't rotate , but stays put.. [mad]Charlie Mac said:+2NuggyBuggy said:The vacuum port on the K5 is a joke - it will not stay in.
The vacuum port was really surprising over how rugged the older K4 port was. I am still amazed that Kreg hasn't been forced to offer a better port for the K5 [mad]
That's odd. The vacuum port on my K5 does not fall off. In fact, I cannot even pull it off. Wonder what the difference is?
You'd really know it if you had the flimsy version... [embarassed]
The box tabs of the K5 port will pop out of where it attaches to the jig with no real pressure. Which means when you hook a vacuum hose up to it, the added weight makes it that much easier to pop the dust port off. [mad]
