Anyone have a good jig or technique for scarfing hardwood?
rmwarren
I am looking for suggestions on how to scarf hardwood and sometimes plywood so I can join up longer lengths. There are lots of router jigs on the web, all basically the same, but I thought I would ask the question to see if anyone has a different technique before going that route. The router jig's all look similar to this:
[attachthumb=#]
I will probably use it as much for hardwood as plywood, so something more compact would be preferable.
Thanks.
RMW
Draw the lines for the scarf joint, then rough it out with a portable power planer then fine tune with a hand plane. It's pretty fast once you get the hang of it. The RAS with 24grit can also rough out pretty fast without all the shavings.
Are you building a boat?
Curt
