Lou Miller
- Jan 22, 2007
Tezzer said:Lou Miller said:I'm also wondering if there is a reason why you'd even have to round many of them over? According to what I've read, the tool is designed to make the first mortise a snug fit.
Howdy Lou. I make my own tenons and its very cost effective. I havnt bought any for over 5 months and i have solved a big scrap wood problem.
The size i make most is 55 x 32 x 10mm and i dont bother with rounding over, instead i set the fence on the jointer at 45deg and set the scale to 1/8th and chamfer all 4 sides. The chamfer is "perfect" for excess glue to escape and the small flat on the end locks into the rounded mortice just beautifully. And i usualy dock a bunch of 6 or 7 at a time on the cross cut sled, so its quick and safe.
The longer you all have and use your beloved Domi the more you will find unusual things to do with it. And that means using heaps and heaps more Domis than you would have thought. So it dose start to add up in the $$$$ so it makes perfect sence to save all those 10mm + strips you rip, and once a month spend a lazy sunday morning and rip up a few hundred tenons ;D
Thanks Tezzer. I'm not too concerned over the $$$. By the time you factor in your time and utilities, the cost of buying Dominos vs. making them has got to be very close to equal. However, like you said, the best reason for me is to use up all the scrap. A lazy Sunday morning is exactly when I'll make mine too. Okay, maybe at 3AM when I can't sleep some nights, but most of the time it will be on lazy Sundays...
