I have the Minimax FS35 (12") combination machine, and I'm very happy with it. I bought it as a demo machine from a woodshow (they didn't want to ship it back to Texas). I had initial problems in that it had not been repacked properly, so that the outfeed table hinge pin and the fence were both damaged in shipping. They were prompt in responding, but a little slow in getting the parts to me (I suspect that the hinge pin is not something that ordinarily has anything go wrong with it, so they may not have had one in stock), but there was never any question that they would do so once I sent them photos of the damage, and they sent me an extra set of knives for my patience.
Once set up, I have had NO significant issues. It is accurate, easy to change from jointer to planer and back. I have the American-style guard (which I prefer) rather than the European-style shown in the video. The American-style guard they supply is plastic and it has to get a bit stressed to pass by the dust collection hood when shifting between modes. Mine eventually cracked, and I made my own out of a short scrap of wide cherry, using the original as a pattern. No problems since. I also replaced the plastic handwheel for raising and lowering the planer bed with a cast iron one, but that was gilding the lily: I prefer the momentum that you get for large changes with a cast iron wheel. The indicator for thicknessing is metric, so I have a conversion chart attached next to it. It is also adjustable.
The Tersa knives are, as the video says, very easy to change, and they align automatically and accurately. An advantage not mentioned in the video is that if you should get a small nick in them, there's a little bit of lengthwise play in the slots, so that you can tap one knife in or out slightly and eliminate the ridge on your planed surface. There was not an option for the helical knives when I got mine -- I probably would have sprung for it for the noise-reduction. The Tersa knives are as loud as any other straight knives. On the other hand, they are so easy to change that you are not tempted to put off changes when the knives are a bit dull, and sharp knives are significantly less loud than dull ones.
