jonny round boy said:Only way I could think to go would be to put in a plinth block, like this:
Then do a skirting return onto the side of the plinth block at the LHS, and just butt the reduced-height up to it on the left.
Locks14 said:What about tying it together with two bullseye corner blocks on each side of the corner and use the smaller skirt the whole way round?
Kev said:This is one of those "no win" corners. Personally I'd take the lower skirt coming from the right all the way to the corner and cut it at 45 degrees. Then cut the left higher piece at the opposite 45 to align above the start of the lower skirt's mitre. Then you'll just need to cut a small piece to bring the profile pattern down vertically (a small triangular shaped piece with the profile on the left).
If I'd had a little less wine to drink I'd sketch it [sad]
G3Trim said:This is the best looking way of doing what your stuck with. You'll need to rip off the top profile from a piece of base miter it and glue it onto the side coming down. I included a rough drawing, hope it helps.[attachthumb=1]
kieran62 said:Had a similar situation a few weeks ago, skirting coming over a step that was higher than the skirting level in the adjoinging room. I got over it by returning the skirting, a little fiddly; but some mitre mate solved the problem.
A quick and dirty sketch to show what I mean.
Kieran[attachimg=1]
Wuffles said:That's why I hang around here, every day is a school day and people can be so helpful.
kieran62 said:Sorry to butt in again [smile], I think you're right, looks like a design feature when recessed.[attachimg=1]
jonny round boy said:By the way, I meant to ask earlier, but forgot [embarassed]
What's the name of that skirting profile? I've not seen it before, and just curious.
